Brake light switch
To all BDR owners you may find an issue with the mechanical brake switch. Reg is reporting problems and I have experienced the issue myself. Now to find the best solution.? Reg is recommending a hycraulic type switch but that to has been problematic due to the heat from the headers. I am working through using a plunger type switch found at ron francis wiring for about 9.95 a simple but problem free? solution. Would need to add a bracket to hold the switch in place and drill or weld a stub to the brake pedal to have the switch rest against.
Anybody have a gfood solution?
