The pistons should show you by way of an arrow or a stamping that will say FRONT. Did you check when you installed them?
Plus the instruction sheet that came with the pistons should show how to install the valve notch. Or is all else fails an engine HOW TO BUILD book would come in very handy.
One other small matter. Did you install the rods the right way? Yes it matters.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
