Old 03-27-2005, 08:34 PM
Trueoo7 Trueoo7 is offline
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
Have you checked to see if both fans are working also look at these as well.
Coolant level
Coolant mixture (too much water?)
Was the system properly filled and purged of all air, you could have an air gap.
Do you have any type of screening in front of radiator.
The bottom of the stainless steel tank has a rubber hose that makes a 90 deg turn, I've seen this hose come from the factory with a kink in it. Mine did and I replaced it with a better more sweeping 90deg hose.
Just somethings to check
Trueoo7
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
