Gatorac,
Check to make sure that the fans are pulling air from the front to the rear of the radiator. I was doing a cooling systems check on my BDR before I started the engine for the first time back in December and found that my fans were wired in reverse and blowing air from the rear of the radiator towards the front. Who ever wired the fan plugs at the factory had them reversed. I corrected them and cooling is not a problem. Easy way to check is put a sheet of paper in front of the radiator with the fans on and see if the paper gets sucked into the radiator surface.
Hope this Helps.
Wayne W.
Backdraft Racing BDR144
Pewter with Steel Gray Stripes
