03-28-2005, 01:21 AM
Ca
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Pete...You can re-anneal the copper gasket by torching it until it turns red hot and then quenching it. It'll be soft as butter and seal better than a new one.
