I've heard that a lot of rods are only able to be driven to & from an event or on special permits. Not sure about the facts of this though, but is that a limitation you'd want on your car. Not being able to drive when you want??
If the motor looks stock, clean but stock then how are the EPA knobheads going to know if you've stroked or polished or ported or balanced.
I know the usual plan is to put rocker covers with big writing about Edelbrock or Trickflo etc but if you hold off on the show pony gear then you should have a better chance of cruising through a spot inspection.
My 2 cents worth
Batman
Please have some sympathy for the HP challenged
