  #35 (permalink)
Old 03-31-2005, 11:54 AM
RedCSX1's Avatar
RedCSX1 RedCSX1 is offline
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Default 10.5-1 compression
Edlebrock aluminum heads bare. Milled .003 to insure the surface is flat. Because the cutter that Eldebrock uses makes mulitple passes over the aluminum head. You should have the machine shop mill the head suface insure they are square or perfectly flat. But I guess you knew that already.
Morgan
Morgan LeBlanc
Fresno CA
