Hey Chuck, Something doesn't "add up", the Tilton release bearing should work. You'll need to take measurements to prove to Tilton and yourself that it will work. On tilton's web site I downloaded the installation instructions and they are very clear with measurements and diagrams for this 600 series bearing. Since I am getting ready to install mine this spring and I plan to use the same Centerforce clutch (149000) in my WC. I have decide to use an OE cast iron bell housing not the Lakewood housing. The Tilton part numbers should be 61-613F (base)and 61-604 (bearing) for the trans we use in the WC cars, the adjustment range in the Tilton table shows an adjustment 2.66" - 3.38" . They explain in the instructions how to measure it. Check this out and see if it measures OK. Let us know what you measured
Bill.
![Confused](images/smilies/confused.gif)
