04-02-2005, 11:03 AM
Ca
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Thank you Jack... I need the PF43 to clear and I'm running a Performer RPM with no clearance problems.....guess I have the later mounts.
