Thread: Tire clearance
Old 04-03-2005, 12:35 PM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
In my case, with the Contemporary body and Jag front and rear suspension the rear tires is no concern, could probably even take a 325 like the BFG drag radial.
The front with a 245/60-15 is tight, and I would not go wider unless you raise the car and increase ground clearance. It all depends on the offset of the wheel.
It probably is very dependent on which Cobra you have. In any case, the 245/60-15 and 295/50-15 have the same height and look "right" on the car. I have the white letters in the inside, so unless you look close you will not see the Yokohama name on the tires.
Nothing sounds better than a Cobra in a Tunnel !
