Excaliber,
what does your car weigh in at? I think I am around 2500 lbs without a driver, but with a full tank. Maybe I will try lower pressure settings. The wheel feels a little light at 30 lbs. Do you think I should run additional toe out or in? What about high speed stability, should I run less positive caster with these tires?
My current settings are:
Front:
-1* Camber
2.5* Caster
1/16 Toe in
Solid rear axle.
--Mike
