Roscoe: never liked the idea of trying to screw the dash up into the lip of the cowl.
This is what I did. I made (2) brackets off the fire wall they are about 10" long. At each end there is a bend at 90 degrees. I bolted the brackets to the fire wall and bolted the dash to the brackets. The brackets (2) are about 3 to 4 inches from either end. Then I bolted the dash to the transmission tunnel on each side. I put chrome bevel upholstery washers under flat head machined screws.
Once in the dash is very stabble.
Hope this helps.
Jim
