Ant....many SB trannies are different....I would say the Jerico would even be a little different than a T5....If you look at Lakewood's catalog, you can see which bellhousing fits which tranny.....pretty sure the Jerico & Toploader would be a different length than a T5....or G-Force.
So I guess the answer to your question is that there are a bunch of possibilities there....you will just have to pick your tranny, pick your bellhousing, then go from there....Once you get those two nailed down, you should be able to call anyone and tell them what you got and then they can provide you with whatever parts you need.
