Old 04-04-2005, 09:20 PM
Ant Ant is offline
Default SBF Trans etc
Blykins,
Thanks, I have worked out two issues the front shaft is 6.361", so a Lakewood 15-200 should do that! Then its a button clutch with a flexplate between that and the crankshaft, and I think I will use a twin plate Tilton Rally clutch, and hydraulic throw out bearing.
Jerico have received a deposit on a five speed transmission with:
2.772
1.925
1.474
1.204
1.00 on 3.27.1 diff and 25.6" diameter tires
So I am commited to a Jerico but can change ratios if necessary!
A J. Newton
The 1960's rocked!
