ERA 535 SPECIFICATIONS
Body & Interior
- ERA Automobiles replica 1965 AC Cobra, chassis number 535
- Testarosa red paint with polyurethane clear coat. Frame powder coated black
-body rivetted and bonded to frame by ERA
- Rectangular Lucas tail lamps
- Riveted on hood scoop attached with polished stainless button head screws
- Powder coated black bumper jacks mounted on car (street front & rear bumpers new in box)
- Nomex & Dyna Mat heat and noise insulation throughout - custom vents to exhaust header heat into wheel wells
- Black leather seats, dash, door hinge covers, rear end access panels
- Cobra logo floor mats, toneau cover and soft cloth car cover
- Simpson competition lap belts and shoulder harnesses
- ERA replica steering column
- Moto-Lita steering wheel with AC insert
- Windshield wipers and washers
- Glove box, with unused cigarette lighter and unused ashtray
- Polished hand brake and leather boot as original
- Aluminum AC logo clutch and brake pedals
- Chromed aluminum fire extinguisher
-PROSHIFT LITE, & O2 sensor readout mounted under the dash
- Smiths gauges in with reverse reding speedo in street layout
- Chrome roll bar
- Dual side spun aluminum mirrors with polished aluminum attachments brackets on side of windscreen
- Side wind wings and tinted sunvisors
- Detailed and carpeted trunk
- Aluminum engine bay dress up kit
- Header engine bay heat shields
- Finished underside of hood and trunk lid
- Side pipes with HTC coating
-Tonneau cover and soft fabric car cover
Engine
- Original 427 side oiler, stroked to 450c.i w/ 428 IUA crank ., blueprinted and balanced and machine work by Bob Santilini, date coded 1965 block, 11:1 compression but runs fine on pump gas
- Edelbrock Performer aluminum heads that are ported
- Edekbrock Medium rise intake match ported to heads
- Speed Demon 850 cfm carb w/ turkey pan - w/ S&H air cleaner and
14" drop base air cleaner
- Eagle rods & Ross pistons w/ Child piston rings
- Comp Cams roller cam (645lift & 248intake & exhaust duration)
- Harland Sharp roller rockers with Dove stands
- Edlebrock Aluminum water pump
- Avaiad
oil pan
- O2 sensor
- Remote high pressure
oil cooler & filter with stainless steel braided lines
- full MSD ignition with control box with rev limiter chip mounted under the dash
- Optima battery mounted in trunk (new 11-10-04)
- Heavy duty ERA brass & copper radiator with modified outlet pipe
- Large puller fan 180 degree thermostat switch
Transmission and Drive Train
-Wide ratio top loader with big in and big out
-Hurst shifter
- Aluminum flywheel
- Lakewood scattershield
- Jag 3.31 to 1 limited slip rear axle ratio
- Auburn Pro Limited slip and Chrome moly stub axles
Suspension:
- Adjustable coil over shocks
- Independent front and rear suspension w. unequal length upper & lower A arms
- Rack & pinion steering
- Front anti-sway bar
- Trigo Pin drive / knock off wheels with brand new Goodyear Eagle racing tires
- Wheel hub centers custom machined from billet AC logo w. black background
- Inboard rear brakes
NEW FORD GT BEING BUILT, MUST MAKE ROOM IN THE GARAGE
$59,999.00
