Old 04-04-2005, 11:22 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Did you buy the wheels new from Trigo? There should have been a adjustment ring in there packed with the hubs.
If not e-mail me with your address and I'll send you one to use if you send it back.
To cut the wheel studs I just used a cut off wheel on a hand grinder. Measured the distance needed from the brake face then ran a stock type lug nut down to the mark cut the stud to the outside face of the lugnut then backed the lug nut off. I asked a couple of people if the heat generated would effect the lug and was told no. Your other choice is to pull your rotors and then install new lugs the length needed.
Do not forget to use antiseize when instanlling the wheels and spinners to the hubs
