Old 04-07-2005, 07:55 AM
Chris D Chris D is offline
Cobra Make, Engine: RMC. 306 Windsor, TFS Track Heat heads, X303 cam, TFS Upper & lower manifold. Accufab t/b, 24 lb inj's, Autronic ECU. Tremec 5 speed,
Default One Shock per side
Guys
RMC did it (One Koni and a heavier spring mit nothing on the other) as an extra cost option. Perfectly OK recalling the rear end weight of a Cobra. Mine was built that way and has had 7 years on the road with no problem. Ride is, if anything, too soft so could do with additional 50 lbs in the spring.
Makes for less room.
Mikes mod looks good and is reminiscent of Concours West's rear end.
Hope it helps.
Chris
