  #63 (permalink)
Old 04-07-2005, 08:45 AM
Three Peaks Three Peaks is offline
Alex,
Thanks for the info- my poorly worded post also left out some information.
I'm looking to use the T-bird IRS in my build as I don't care for the Jag rear end. To this end, I need to fabricate some rear swing arms for the T-bird IRS and shock mounts, etc.... I need the original dimensions for a base line to design the new swing arms- upper and lower, but they will be substantially different than the Jag type swing arms. I'm aware the pick up points are on the drawings, but I need information on the suspension pieces to help me design these pieces.
Also, in the front I was wondering which A-arms would work with this set up and you've answered my question with the Mustang II information. Which units are you using? I've looked at the different units available on the different sites on the net and the list is endless. I would definitely like to use the adjustable uppers in the front and rear for camber/caster adjustment, but figuring out which ones to use is bewildering.
Sorry, I went back to your past posts and found the information on who to talk to.
Thanks again for your help.- Bob
