Old 04-07-2005, 01:45 PM
ItBites's Avatar
ItBites ItBites is offline
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
The best fasteners for exhaust that I have used are made of A-286 stainless steel. Do not use the 300-series stainless steels as these are not only not very heat resistant, they are also very weak. I really like the NAS1351N - series fasteners for this type of application, since they are designed for lap-joint applications and have a long shank and short threads (threads are not in line with the split). Pegasus may sell them or you could try McMaster-Carr, but I usually get them from the local fastener distributor (Copper State Nut and Bolt). They are not cheap and often have to be ordered.
Also, I agree you likely have higher than normal temps (timing or mixture), but if you go to A-286, they won't get brittle...
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
