Old 04-08-2005, 09:00 AM
bfreer's Avatar
bfreer bfreer is offline
Cobra Make, Engine: Classic Roadster II with 351W/TKO500
Default Ford Rear Discs
Petek,
I also have strruggled with the screw in piston. They make a tool that attaches to a ratchet to screw them in. I used a cordless drill with the adaptor on low speed/high power setting to screw them in. It was much easier. It may also help to loosen the bleed valve, to give the fluid somewhere to go when you screw it in. Just bleed the brakes after.
Brian
Life is not measured by the number of breaths we take, but by the moments that take our breath away.
