Thread: 429 CJ parts
Old 04-10-2005, 10:33 PM
Rory428 Rory428 is offline
Default 429 CJ parts
I have a 429 CJ/SCJ 4 bolt main block D0VE-A for sale. It is .040" oversize, but will need 1 sleeve installed due to a cracked cylinder, caused by a broken valve. As is, $400.00, or I can have it sleeved locally for an extra $150.00. I live 3 hours North of Seattle Washington, & would prefer a local pickup, rather than shipping long distance. I will be racing at Pacific Raceway in Washington state on April 23-24th, if any Seattle area person is interested, I could bring the block with me.
I also have a set of 8 429 CJ connecting rods, casting number D0OE. These are used rods, & should be re conditioned. $100.00 set. I can ship these rods anywhere in North America.
I also have another 429 , a D0VE-A 2 bolt main, also .040" over. This is a short block, and has forged pistons, flattop with a single eyebrow (CJ replacement, I believe. The eyebrows have been deepened for more valve clearance, but 1 piston is no good from another dropped valve. There is some minor marks on the cylinder wall from debris, I would reccomend going .060" to clean everything up. There is a cam & lifters, which I believe was a Comp Cams solid setup, but I`m not positive. It also has a custom built steel deep, flat sump oil pan. This engine has been sitting for 12 or 13 years, & belonged to a deceased friend, who ran it in a Cobra. It is possible for me to pull the pan & give a closer look if desired. We would like $200.00 for this short block, local pick up only. Thanks.
78 Fairmont 428CJ 4speed ET10.03@132.17mph
1985 Mustang 302 5speed 12.31@106.9mph
