Bob,
Thank you for the compliment on the pictures!!
After I complete the other side, I will fabricate the skock mounts. First I have to finish the other side, complete the cross braces, then fab the shock mounts as they are reinforced back to the cross bracing.
Once my hard learned geomentry lesson is over, the rest will be pretty simple stuff.
As for the spindles, they are also from Pole Position.
Right side 9309
Left side 9302
Rotors are also Pole Postiton 9440 11" (same as Granada) with Ford bolt pattern.
The "only" reason the name Pole Position keeps coming up is that Ted spent lots of time answering questions and helping me over the phone so I went with them.
If I was building a more conventional set up I probably would be more help.
However, If you have any questions, I will try to help.
I am really suprised that some of the other builders have not supplied more information.
Thank you,
Cobracer#15
