Old 04-12-2005, 11:36 AM
slithering slithering is offline
Cobra Make, Engine: Midstates, Genesis 427 S/O
Brent,
What is your voltmeter reading at idle? If your charging it should be 14 vdc or so. Check your voltage output at the regulator, this might be your culprit. Does the car run on after the key is off? Could be a resistor problem, sounds like a regulator though.
Chris
"God saved you by His grace when you believed. And you can't take credit for this; it is a gift from God".
Ephesians 2:8
