  #29 (permalink)
Old 04-12-2005, 05:42 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
By all means... be my guest. I can provide you with higher res alternates as well if you like. Just let me know.... Also would like to see the thread when you have it going...
