thanks for the info:
Pull the trans out and takeing it to power by ford in orlando.
the tail shaft bushing has a lot of play in it. i still believe that no
oil was getting back to the yoke. because when I broke a u-joint and pull it out it was bule from the heat and was also hard to pull out. Frank replace the driveshaft because the u-joint was to small and replace the driveshaft he was a big help. let all you know how it come out.
ED
