04-13-2005, 10:24 PM
Ca
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
If the dura spark is the standard Ford electronic ignition box I have at least one or two laying around from pre MSD days. You're welcome to one if you need it.
