Old 04-15-2005, 10:11 AM
sideoiler10 sideoiler10 is offline
Cobra Make, Engine: Shell Valley, '67 Cobra, 1966 427 sideoiler, 2x4s, w/NASCAR toploader
Default Blue Thunder 2x4 FE Intake
Can someone post the height dimensions from the rear center manifold base up to the carb base on the BT 2x4 Low Riser FE manifold?
I just received one and man is it tall. I know I have seen several other Cobras with BT low risers and some with med. risers that fit under a standard Cobra style scoop. How do they do it without the oil pan dragging the ground?
Thanks a'bunch. Bob
