Old 04-15-2005, 11:29 AM
sideoiler10 sideoiler10 is offline
Cobra Make, Engine: Shell Valley, '67 Cobra, 1966 427 sideoiler, 2x4s, w/NASCAR toploader
Default FE 2x4 Blue Thunder manifold
I am running a cast alum. "Cobra" pan that is just an inch above the crossmember. What brand intake are you using? As I said in my first post, the low riser I just received is so tall it won't fit under the hood scoop. At first I thought it might be a medium riser but was told no, it was a low riser and that the Blue Thunder LR is just tall. Doesn't make much sense to me but some people would say that's normal!
Do you know if there are different heights of low risers out there? I know the OEM FOMOCO model is fairly thin in height.
Thanks again for your input.
