Old 04-15-2005, 09:35 PM
JustOne JustOne is offline
Cobra Make, Engine: Unique FIA, 425 Windsor
With a girdle and proper machine work you can run about 700 hp if you are not detonating. Any higher and you will need to get an aftermarket block. The problem is that the bottom end of the block cracks much above 700.
