LS1 trouble
Hi All ,
I just got my exhaust done (will post pics soon) but the problem i am having with the motor is that the Left Hand Sidepipe after about 1-2 minutes will be glowing red . The motor has a consistant miss have you guys got ant ideas for me .
All the plugs are new and they all fire as i have tested every one on there respective leads . I pulled the fuel rail of and turned it upside down then reconnected the injector plugs and turned the key and all the injectors are squirting . Fuel pressure is set to 55 psi or 380 killopascals .I also swapped oxygen sensors to no avail
Any Help would be much appreciated.
Paul
