Old 04-17-2005, 11:58 PM
phatry5 phatry5 is offline
Cobra Make, Engine: FFR 302 bored 306: 370HP
Send a message via AIM to phatry5
If it's an older holley definetly check your power valves, although you will usually have more problems than just heavy acceleration. You might want to check your plugs and distributor too. If leaning out doesn't fix it, try a 6AL to enhance your spark. Doesn't sound like timing, unless you are idleing rough and running hot.
Hold on tight!!!
