Old 04-18-2005, 06:00 AM
jess jess is offline
Cobra Make, Engine: classic revival 302w
Default master cyl sizes
heya all do any of you guys that have the cr chassis running running std brake setups i need to know what master cyl sizes to run i will be running the braided lines as ive been told pedal travel can increase by up to 4 mm between rubber and braided but the engineers at work think im crazy they rec i should run 1inch bore with booster with a prop valve as i would not be able to achieve full preasure with unboosted brakes
so if theres any of you out there that are driving around with the twin cyl setup i would be intrested in your opinion on how they stop and feel would be much appreciated as i gotta put something in there soon
also what size are you guys running for cluth master cyl
confused
jess
