The big difference with the Cleveland heads is that the valve reliefs machines into "off the shelf" pistons will be based on valve angles of Windsor heads. For the same reason that you need pistons specific to a TFS-R head, or a Yates head, you need to match the piston design to a Clevo head.
Craig
