Old 04-22-2005, 06:28 PM
Enginetime Enginetime is offline
Cobra Make, Engine: ERA#173, Genesis 427, Scat stroker 452
Default 428 Engine for sale
428FE ready for assembly with the following: Block 390,C3ME-A sonic checked,pressure tested to 65psi,deck plated,bored 428 std. 4.13, finished honed, new cam bearings installed,precision oil pumps kit, lifter valley and timing chain areas gluzite coated. Oil mods done, oil filter adapter,melling oil pump, hardned shaft,block painted VHT ford blue. Teflon coated main bearings set, Stock 428 crank 10-10 with stock harmonic balancer, C7AE rods,ground refinished with ARP bolts, TRW/Speedpro forged coated piston set,Speedpro rings, Head 5L23/5M23,ported for 428,newvalves,guides,springs,seals,complete with stock rocker assys,ready to bolt on. Crane hyd.cam and lifters,stock(rebuilt)ford distributor,timing chain set,timing cover with pointer, stock water pump,oil pan,flywheel(resurfaced and crack checked),diaphram pplate,disc,to bearing,bellhousing(C5TA-7505-B beaded and primed),perfect alumacoated spacer plate,fuel pump. Rotating assy balanced. No junk,all work prof done. My bulider will assemble if you wish.
Optional new in box Edlebrock AL heads, for 390/428, BARE, with oil restrictors installed and return hole mods done. Located in MA,call 978 346 0686 with questions.
$6,300.00 or 7,200.00 with AL heads
