Here is a list of parts I used to pass my 69 351W motor at the CA BAR for smog purposes. YOUR REQUIREMENTS MAY BE DIFFERENT based on your specific engine/needs. For example, you need a CA compliant carb, non modified engine. The following items fit on my 2001 Superformance (car # 995):
Themostatic air cleaner with heat riser (getting it's heat from the headers) - Motorcraft air cleaner included. This has been customized to fit under the hood and my hood closes fine (it may not be the same under your hood!)
Motorcraft distributor with vacuum advance; comes with cap, rotor, and check valve.
Motorcraft Spark plug wire set long enough to go around TAC.
Oil Filler cap with breather.
Asking $350 + $50 shipping/packaging
See pictures and more info here:
Click here for pics and info
