Thread: Parts For Sale
Old 04-27-2005, 06:16 AM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
These headlight units are "sealed beam replacement" units. You remove the sealed beam lamps and replace them with these units. They look just like the sealed beam lamps and fit the bucket perfectly, except these units have replaceable H-4 halogen bulbs. The 7" round unit is a double beam light, therefore it has both low and high beam just like the original sealed beam and your three prong lamp socket will fit perfectly. This lamp will replace perfectly any 7" round headlight (Cobra and many others) The only thing you will see after installation is a brighter headlight beam and the white light rather than the original sealed beam yellowish light. If you like, you can replace the halogen bulbs in these units with the new Xenon bulbs for an even whiter and brighter light.
This kit does not contain buckets, trim rings, gaskets, screws etc. It is TWO replacement lamp housings and TWO H-4 bulbs.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
