Thread: amp meter
Old 04-27-2005, 02:07 PM
mylesdw mylesdw is offline
Cobra Make, Engine: Ram 427 SC CSX6042. Chev 355. Quad Weber DCNFs
Send a message via ICQ to mylesdw
During normal driving it should be in the middle or very slightly to the positive side.
After starting the car, you should see a fairly large charge into the battery and then this will disappear within a few minutes.
When you switch on something like the fans which draw a bit of current, you should see the needle flick to the negative side and then recover immediatly (as long as the engine is running). It should never show a continual discharge.
It does sound like a problem with the charging system.
Myles D-W
