Tim:
Its 9:00 pm Houston time and I have not received the pics of the reversing plates. If you could send again I would appreciate it.
Chuck:
If it turns out that the reversing plates can be made, I would buy them from you if you can make them. Also, do you have anymore detailed pics of you 351 linkage setup. Could you send them to me like you did before at
Lubrecon@aol.com.
I am jetting 60 idles, 200 air correctors, 160 mains, 120 idle holders, F7 emulsion, stock 50 pump jet, closed pump exhaust, and 37 mm chokes. I think I got this from you Chuck. Does this look about right. The engine is a 351W stroked to 408, from Coast High Performance. I am going to use a Carter 4070 fuel pump. Some say no pressure regulator with this pump, others say a must. What do you two think?
Cal any comments about this set up?
Thanks to all of you.
Jerry Shelby
