Lubrecon- I agree with Ford of France. Your jets/ hardware sound right. If you need photos of the intake with the center throttle shaft and none of the other guys can post (I really doubt that) I can send you some.
The side pull set-up was originally made for GT350s; in fact, back in '65 when they sold weber intakes over the counter they offered either the "cobra" or "GT350" style.
Traindriver, you got it right. The only thing different about what Iglese sells from your design is the Inglese plates are longer with two holes so you only need four plates, made of aluminum about 3.0mm thick and the one on the passenger side front has a shorter lip extending out to keep from hitting the throttle shaft where it sticks out the front of the carb body. Great job! I tried to get something like this made locally and labor was outrageous.
Any of you going to the Shelby spring fling in Indiana May 20-22? If you do make sure you find me.
Tim
A good friend will help you move.
A real good friend will help you move a body.
