Thread: Sidepipes.
Old 04-28-2005, 10:35 PM
Mando's Avatar
Mando Mando is offline
Hi Gavin,
I wish that shed was mine. It belongs to the guy making the sidepipes. I also wish there was a 100% foolproof answer in setting up my exhaust to meet the required 90db with my motor. I dont mind running two pipes from the rear of the sidepipes up over the suspension in the wheelwells and out the back with a couple of custom muflers on each side but I dont think Ive got enough room for it. I also didnt mind Ledges setup with the two pipes collecting in the middle of the car and exiting out the back under the tank. In my situation it would end up to low.
A couple of guys have told me the only way Im going to get to 90db is to remove the sidepipes up to the extractors and install a 1 3/4" under body system. Installing the system doesnt bother me, its the extra holes to support the pipes that will anoy me. I had a look under the car last night, and I should be able to fix brackets to existing bolts such as the seat bolts.
Regards.
Mando
