Old 04-29-2005, 10:07 AM
BDRCobra BDRCobra is offline
Thanks for the replies!! If it does not rain this afternoon I am taking it in. Just as a side note I found a couple areas of looseness in my steering which were a 3 minute fix. First was the connection from the steering box to steering shaft. The allen head screw was not completely tight. Turn your steering wheel for easy access to the head and tighten it. The second was where the steering shaft slides into the column. There are two little screws that hold it from turning. Those were also loose. I tightned them and now if you move my steering wheel a mm you will move the front tires.
