Old 04-29-2005, 07:05 PM
RC14 RC14 is offline
Cobra Make, Engine: None Yet
Vinstang I would do a mach up just in case if i was you. Are you using the 2.08 or the 2.25 intake valves. I am building a 429 as well but i am using a 460 crank and stock size rods and 11.1 pistons and the big valve, cam is going to be around 305 adv duration and 610 lift. 72cc heads, i will mach up for sure. good luck
