Old 04-30-2005, 12:59 AM
Keithc8 Keithc8 is offline
Default Shelby Aluminum Engine Special
We have in stock Shelby blocks with 10 Scat billet cranks due in about 2 weeks. I have decided to offer to the Club Cobra Members a special price on 5 Shelby complete engines. These engines will be 482C.I. with the following parts. Shelby aluminum block and head studs, Scat 4340 billet crankshaft, Scat 6.700 H-beam rods, JE custom pistons, Mahle rings, Federal
Mogual bearings, zero balanced, Comp Cams hydraulic custom roller camshaft, Ford Racing double roller timing set, Armondo oil pan, windage trey and pick-up tube, Melling HV oil pump, Ford HD oil pump drive, Shelby front cover, BHJ SFI damper, Edelbrock aluminum water pump, Crane hydraulic roller lifters, Smith Brothers pushrods, KCR Edelbrock stage 2 heads with ends milled, Erson roller rockers, Shelby dual plane intake, MSD distributor and wires, Shelby valve covers or Ford Racing Cobra valve covers, gaskets, ProSystems 950HP carburetor and studs, Aluminum water pump and crank pulley with standard style alternator and aluminum brackets with belt, Ram aluminum flywheel, aluminum remote adapter for oil cooler lines to engine with complete build sheets and balance sheet, dyno tested with dyno sheets. These engines will make 625 torque and 625HP on premium pump gas with 10.5 to 1 compression. The complete package as described above will be available for 21,995.00. These can be built in about 10 weeks from deposit date. Other options can be added at aditional cost such as large bore block, T&D rockers, 2X4 intake set up, stage 3 heads, bellhousing, clutch pressure plate among others. Thanks, Keith Craft
Keith C
