Old 05-02-2005, 11:03 AM
Doug I's Avatar
Doug I Doug I is offline
Cobra Make, Engine: Waiting to Order a BDR, engine to be a SA C408. TKO to hook it up.
The best gearing for your car is a function of the HP and torque curves from the engine, the rearend ratio, wheel size and type of driving you typically do.
All said and done the most common TKO I'm seeing used (from posts here) is the 600 with the 82 5th.
HTH
regards
Doug I
Pull a gear .... drop the hammer .... and enjoy the Drive !!
