Old 05-02-2005, 04:25 PM
pneall's Avatar
pneall pneall is offline
Paul , David,
Yes the grub screws at the back are connected to the oil gallery. The back one goes to the bearings and the front one is from the pump.I plan to install an accusump in the rear plug and also put oil pressure sensor / switch here also.
I have removed front oil filter and added an adaptor then put in a remote filter and cooler. You need to run min -12 for coolers etc.
The accusump is purely a preoiler as I figure the extra routing of oil and original design could cause oil starvation on start up.
David, I'll measure my cooler and let you know.
Phil
