Old 05-02-2005, 08:49 PM
Rory428 Rory428 is offline
I have deal with FPP several times over the years, mostly with positive results. The only real complaint I ever had was that when you place an order, they will bill you for everything you ordered, but if anything is out of stock, you won`t find out until your order comes in, with a slip ststing that such & such a part is on back order. Fortunatley for me, it was usually something fairly minor , like header gaskets (great gaskets, plus they actually FIT, unlike the Mr. Gasket stuff!), and they were normally sent within a couple of weeks. I supose the best situation would be if you live within driving distance, and can deal in person. Otherwise, be certain to ask if everything you want is in stock, & will be shipped al together. As for rockers, I really like my Erson roller rocker assemblies. They come complete with shafts & stands, all assembled & ready to bolt on. I believe that these are the only rockers that use needle bearings on the shafts, at least for under $2000.00 dollars. The T&D & Jessel rockers are also needle bearing shafts, but in addition to costing 2 to 3 times as much, also require non reversable head modifactaion to fit, not to mention pushrod oiling is required.
78 Fairmont 428CJ 4speed ET10.03@132.17mph
1985 Mustang 302 5speed 12.31@106.9mph
