Old 05-06-2005, 07:34 AM
392cobra's Avatar
392cobra 392cobra is offline
6th Generation Texan
Default Cooling/Charging & Pulley Ratios
Thanks for the input on the stock pulley diameters.
Having that data and further digging helped me understand my low speed cooling situation.
1.Stock pulleys overdrive the water pump 10 % on average.
This what Stewart Componets has to say about pulley ratios.Griffin Radiator told me the same thing.
http://www.stewartcomponents.com/tec...ech_Tips_1.htm
2. The stock pulleys turn the alternator 2.5 - 3 times crankshaft pulley rpm.
When the alt. gets down to the 1.75 times range,idle-low speed charging is between little and none.
MARCH PULLEYS
V - BELT, 1969 1/2 & LATER 302 - 351 WINDSOR & CLEVELAND
STREET ROD RATIOS
5.5" CRANK
5.25 WATER PUMP 5% OVERDRIVEN
2 11/16 ALT. 2.05 TIMES CRANK RPM
PERFORMANCE RATIO
5.5" CRANK
6.25 WATER PUMP 12 % UNDERDRIVEN
SERPENTINE BELT CONVERSION FROM V - BELT
STREET ROD RATIO
6 1/8" CRANK
5.5 WATER PUMP 11% OVERDRIVEN
2.5 ALT. 2.45 TIMES CRANK RPM
PERFORMANCE RATIO
4 3/8" CRANK
5.5 WATER PUMP 20 % UNDERDRIVEN
2.5 ALT. 1.75 TIMES CRANK RPM
1979 - 1993 5 LITER SERPENTINE PULLEYS
PERFORMANCE RATIO
4 3/8" CRANK
2 3/8 ALT. 1.84 TIMES CRANK RPM
POWER & AMP
STEEL & POWDERCOAT ALUMINUM
4 3/8" CRANK
1 11/16 ALT. 2.59 TIMES CRANK RPM
CLEARCOAT ALUMINUM
4 3/8" CRANK
2.0 ALT. 2.19 TIMES CRANK RPM
As you can see, some of these pulley sets cut the water pump output by 30 %.
