My BDR has about -2.5 degrees on camber, tires lean in pretty good at top, tried to get it fixed at alignment shop, but will have to take the struts loose at the top or possibly remove them to elongate the mounting holes a little to be able to adjust in to spec. I haven't had the time to do this, not really a major job. I have got over 1500 miles on the what I call (severe camber) but no problems what so ever. Kinda has that bad azz road racer car look.
Also raising the front ride height will take some negative camber out. Though some people likes the low look, like me, will have to deal with the negative camber issue till some adjustment slooting is done, to be able to get spec.
DON
