Old 05-08-2005, 07:31 PM
redUnique redUnique is offline
427 S/O,
With most octane booster product claims, I think you are correct. However, I did quite a bit or research about 2 years ago and this company's claims seem to be accurate. Additionally, the below would be a clear-cut case of false advertising if they were referencing tenths of points. You may want to check it out.
HIGHLIGHTS OF OCTANE SUPREME-130
Contains REAL Tetraethyl Lead (60 grams per gal.) and other octane
enhancing components. (No substitute chemicals added).
Boosts Octane from 2–16 full points
(not 0.1 points but full octane numbers, eg. 91 into a 98 octane, etc.)
when added to fuel. Perfect for high compression engines to
eliminate engine knocking and detonation.
Protects and lubricates the valve train. 12 ounces of OS130 to 20 gallons of fuel provides the minimum amount of lead protection needed to maintain and lubricate engines designed to run on leaded gasoline. Perfect for vintage cars, farm tractors, etc.
A Superior Gasoline Treatment & Octane Booster that is EPA approved and registered for off road use.
TREAT RATES R+M/2______
0.6- Ounces OS-130 to 1 gallon / fuel……2.0 point octane increase
1.2- Ounces OS-130 to 1 gallon / fuel……3.5 point octane increase
1.8- Ounces OS-130 to 1 gallon / fuel……5.0 point octane increase
2.4- Ounces OS-130 to 1 gallon / fuel……6.5 point octane increase
3.0- Ounces OS-130 to 1 gallon / fuel……8.0 point octane increase
6.0- Ounces OS-130 to 1 gallon / fuel……11.0 point octane increase
18- Ounces OS-130 to 1 gallon / fuel……16.0 point octane increase
EXAMPLE: 18 ounces added to 10 gallons of fuel will turn a 93 octane into a 98 octane, 30 ounces into a 101 octane, etc. Guaranteed! Due to EPA regulations this product is for off road use only.
