Old 05-10-2005, 11:26 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Remove the phillips screw at the end of the teardrop...
The glass bowl comes off in your hand...
Locate and remove the two screws at the bottom of the mirror base...
The base comes off in your hand...
There are two screws holding a clip to the body...Here is where you ask yourself..."Am I feeling Lucky"... Sometimes they are just two screws into the fiberglass...But I have been told that occasionally, either by a factory worker on a bad day, or a previous owner, a bolt with a nut inside the footwell was used...
You might be able to check inside the footwell first for a nut attachment first...Either way it's a 5 min or a 30 min job to replace.
FYI...There are also instructions on the SCOF Website's tech section...
The replacement bowl with the convex glass will replace the existing flat glass and bowl on your SPF....
PM me if you need additional info...
Good luck...
